The eyes have it: men do see things differently to women
Nieuwsberichten
Edel_Valk_Havik
Bericht door Edel_Valk_Havik »
Voor de eihoofdjes onder ons :)
http://www.biomedcentral.com/presscente ... /20120904a" target="_blank
The way that the visual centers of men and women’s brains works is different, finds new research published in BioMed Central’s open access journal Biology of Sex Differences. Men have greater sensitivity to fine detail and rapidly moving stimuli, but women are better at discriminating between colors.
In the brain there are high concentrations of male sex hormone (androgen) receptors throughout cerebral cortex, especially in the visual cortex which is responsible for processing images. Androgens are also responsible for controlling the development of neurons in the visual cortex during embryogenesis, meaning that males have 25% more of these neurons than females.
Researchers from Brooklyn and Hunter Colleges of the City University of New York compared the vision of men and women aged over 16 from both college and high school, including students and staff. All volunteers were required to have normal color vision and 20/20 sight (or 20/20 when corrected by glasses or contact lenses).
When the volunteers were required to describe colors shown to them across the visual spectrum it became obvious that the color vision of men was shifted, and that they required a slightly longer wavelength to experience the same hue as the women. The males also had a broader range in the center of the spectrum where they were less able to discriminate between colors.
An image of light and dark bars was used to measure contrast-sensitivity functions (CSF) of vision; the bars were either horizontal or vertical and volunteers had to choose which one they saw. In each image, when the light and dark bars were alternated the image appeared to flicker.
By varying how rapidly the bars alternated or how close together they were, the team found that at moderate rates of image change, observers lost sensitivity for close together bars, and gained sensitivity when the bars were farther apart. However when the image change was faster both sexes were less able to resolve the images over all bar widths. Overall the men were better able to resolve more rapidly changing images that were closer together than the women.
Prof Israel Abramov, who led this study commented, “As with other senses, such as hearing and the olfactory system, there are marked sex differences in vision between men and women. The elements of vision we measured are determined by inputs from specific sets of thalamic neurons into the primary visual cortex. We suggest that, since these neurons are guided by the cortex during embryogenesis, that testosterone plays a major role, somehow leading to different connectivity between males and females. The evolutionary driving force between these differences is less clear.”
http://www.bsd-journal.com/content/3/1/20/abstract" target="_blank
Abstract (provisional)
Background
Cerebral cortex has a very large number of testosterone receptors, which could be a basis for sex differences in sensory functions. For example, audition has clear sex differences, which are related to serum testosterone levels. Of all major sensory systems only vision has not been examined for sex differences, which is surprising because occipital lobe (primary visual projection area) may have the highest density of testosterone receptors in the cortex. We have examined a basic visual function: spatial and temporal pattern resolution and acuity.
Methods
We tested large groups of young adults with normal vision. They were screened with a battery of standard tests that examined acuity, color vision, and stereopsis. We sampled the visual system's contrast-sensitivity function (CSF) across the entire spatio-temporal space: 6 spatial frequencies at each of 5 temporal rates. Stimuli were gratings with sinusoidal luminance profiles generated on a special-purpose computer screen; their contrast was also sinusoidally modulated in time. We measured threshold contrasts using a criterion-free (forced-choice), adaptive psychophysical method (QUEST algorithm). Also, each individual's acuity limit was estimated by fitting his or her data with a model and extrapolating to find the spatial frequency corresponding to 100 % contrast.
Results
At a very low temporal rate, the spatial CSF was the canonical inverted-U; but for higher temporal rates, the maxima of the spatial CSFs shifted: Observers lost sensitivity at high spatial frequencies and gained sensitivity at low frequencies; also, all the maxima of the CSFs shifted by about the same amount in spatial frequency. Main effect: there was a significant (ANOVA) sex difference. Across the entire spatio-temporal domain, males were more sensitive, especially at higher spatial frequencies; similarly males had significantly better acuity at all temporal rates.
Conclusion
As with other sensory systems, there are marked sex differences in vision. The CSFs we measure are largely determined by inputs from specific sets of thalamic neurons to individual neurons in primary visual cortex. This convergence from thalamus to cortex is guided by cortex during embryogenesis. We suggest that testosterone plays a major role, leading to different connectivities in males and in females. But, for whatever reasons, we find that males have significantly greater sensitivity for fine detail and for rapidly moving stimuli. One interpretation is that this is consistent with sex roles in hunter-gatherer societies.
Wit_Delta_Marter
Re: The eyes have it: men do see things differently to women
Bericht door Wit_Delta_Marter »
cool
